Lesser Known Classics Discussion Forum
Deutz Injection timing
Russell Schultz
06-10-2006 19:58:40
hello
I'm wondering how to static time the injection pump on my Deutz F4l/515/5. It has a coupler driven Bosch inline jerk pump. I want to know what markings to line up when installing the pump coupler when the engine is on No.1 cylinder TDC compression stoke. Also need to know if the cylinders are numbered rear to front or front to rear.
Thanks,
Russ
Russell Schultz
06-11-2006 18:34:56
 Re: Deutz Injection timing in reply to Russell Schultz, 06-10-2006 19:58:40
hello. I would like to know if there are any marks to line up for static timing the pump. Or how do I get it to be at about 23 degrees? thanks, Russ
Bernhard
06-22-2006 22:45:01
 Re: Deutz Injection timing in reply to Russell Schultz, 06-11-2006 18:34:56
Look at the clutch housing, there should be a whole on left side. For normal, there are some marks on the flywheel.
Bernhard
06-11-2006 14:37:54
Cylinders are marked rear to front. Ignition is 1-3-4-2. Injection starts at 22-24°
Russell Schultz
06-10-2006 20:00:42
Sorry made a mistake - it"s a F4L-514/5 NOT A F4L515/5. 1963 year.
