Terra trac bulldozer model gt-30
norwin raus
05-16-1999 17:29:02
I am looking for tracks for this model of bulldozer and have run into some problems any help would be greatly appreciated. the chain dimensions for the tracks are a pitch of 6" with an ID diameter of .875 and an OD diameter of 1.25 with lengths of pins and bushings being 2" and 3".
Steve T
05-23-1999 08:04:00
 Re: terra trac bulldozer model gt-30 in reply to norwin raus , 05-16-1999 17:29:02
You might get a hold of a Case-IH dealer and ask them. J.I. Case bought out Terratrac some time in the fiftys, if I remember correctly. hope this helps.
Steve T
Larry
09-13-2001 19:15:07
 Re: Re: terra trac bulldozer model gt-30 in reply to Steve T, 05-23-1999 08:04:00
Looking for a set of bottom track rollers new or good used. or good condition under carriage also someone who has parts for Terratrac gt30 dozer Is there another exchange parts for this dozer? need aproximatly 3 1/8 inch wide, 3 1/2 inch around and 7 inch octegon shaft with cotterpin holes on each end { rollers}
larry
09-17-2001 18:36:01
 Re: Re: Re: terra trac bulldozer model gt-30 in reply to Larry, 09-13-2001 19:15:07
possibley a terratrac dozer gt30 complete for sale for $4000. In operating condition. or best offer above$3500. runs excellent under carriage is ingood condition. motor runs great.steering clutches are at 75% intact. running gears,rear end are 100% please contact Larry
Bill Iman
04-18-2001 15:33:31
Looking for bottom roller for the tracks.
can you please reply
Thank you, Bill Iman
Tom Lager
06-05-2000 19:06:13
need the rail for one side for a model gt 25 or 30
Bill Iman
04-18-2001 15:43:31
 Re: Re: Re: terra trac bulldozer model gt-30 in reply to Tom Lager, 06-05-2000 19:06:13
Maybe you can find it off a trac drill.
Mark
12-30-2001 15:45:38
 Re: Re: Re: Re: terra trac bulldozer model gt-30 in reply to Bill Iman, 04-18-2001 15:43:31
I've been searching for rollers for my GT30 for about 5 years. I'm down to making some forklift rollers work. I had a line on a guy that would make them for me. He fell through. One place that I talked to told me if he could find them, they'd be $200 a piece minimum.
