Lesser Known Classics Discussion Forum
Wisconsin VE4D
Anderson
07-18-2006 16:52:19
Where are the timing marks on a wisconsin VE4D for the magneto. I can not find it.
Gene Perkins
09-24-2006 10:31:38
 Re: Wisconsin VE4D in reply to Anderson, 07-18-2006 16:52:19
There should be a plug on the side of the mag gear housing. When you remove that plug, you can see the gear. As you rotate the flywheel, you will see a mark on the mag gear. That is the timing mark. If you email me, I will give you a detailed description of the timing procedure.
