Lesser Known Classics Discussion Forum
fuel filters
coup
09-22-2006 03:11:27
how often do you change fuel filters on your diesel tractor and do you always change both,if you have two?????
Jim in NC
09-22-2006 17:25:41
 Re: fuel filters in reply to coup, 09-22-2006 03:11:27
If you do not know when they were last changed, change both of them. After changing both of them, I usually change the lower one by itself next, and at the next change, I do them both. On my Long, I can only drain the condensate from the lower filter. The lower filter will be much dirtier than the upper one since fuel passes through the lower one first. I have had my 445 for 25 years. It is in the hayfield now with the haybine behind it and ready to go. Hope this helps.
J Schwiebert
09-22-2006 09:35:27
Just read this and also your oil and filterpost. I think your tractor would have the same recommendations as an Oliver-Fiat built unit.You want me to look in my manual? Stick with the Shell 15-40. On the fuel filter I would change them both in the spring and drain the condensate out of them every once in a while. How many hours do you get on the tractor in a year? Where do you live and do you have a fuel filter on your diesel tank from where you fill the tractor? More questions? By the way the oil filter does cross over to a Ford filter on an Oliver. The Ford filter was smaller in size than the OE filter. J
coup
09-23-2006 03:44:27
 Re: fuel filters in reply to J Schwiebert, 09-22-2006 09:35:27
i live in central wv,,,i have had the tractor two years. the guy i got it from said he had just changed the oil and upper fuel filter.. i probably average 5 hours a week,most is brushhoggin fairly steep ground... it is far and away the best tractor i have ever had...cchanged the oil and used the walmart number for filter given here....Thanks
i have a friend that has two four wheel drive oliver tractors and they seem like really good tractors also.
J Schwiebert
09-24-2006 13:50:55
 Re: fuel filters in reply to coup, 09-23-2006 03:44:27
What do you call "central wv?" I do some work for the WV highway department from time to time and travel to all 10 districts. What model Olivers does your friend have. I was basing my information on the Fiat built Olivers we serviced. J.
coup
09-27-2006 03:00:10
 Re: fuel filters in reply to J Schwiebert, 09-24-2006 13:50:55
tractors are 1255 and 1265.....
coup
09-26-2006 03:21:06
i am in calhoun,friend lives in clay,,,,not sure about models guessing 1455 and similar tractor. he has offered one for sale $4500,i believe.
