Lesser Known Classics Discussion Forum
Hough HMD payloader info needed
LloydBoy
11-04-2006 10:54:37
Found an old Hough payloader model number HMD with a Hercules 6 cylinder diesel engine and 4 wd. The guy couldn"t get it running, dead batteries and trying to start by jumping with his truck. Engine turns over slow, probably too slow to start a diesel. He said it runs and drives ok though. Anyone know about what year it would be and any specifics about it like, how much does it weigh and how much can it lift. Also the HP of the engine and what gas engines would be good candidate to swap in.
jay hall
11-13-2006 19:21:38
 Re: Hough HMD payloader info needed in reply to LloydBoy, 11-04-2006 10:54:37
hey buddy i havent got a clue what year yours or mine might be but someone put a ford 390 and 4 speed tranny in mine and it works great most of the time i run mine in low gear on the ford tranny or reverse works good too ive toyed with the idea of a gm 350 and auto transmission but my loader has no brakes and the standard works pretty good i just hit the clutch and drop the bucket if i get into trouble
J Schwiebert
11-05-2006 06:30:27
I am not good with the Hough payloaders. When I taugh ag-mechanics we had a man the had one and I think that was the model and it was a JX* Hercules. That was a gas engine. The diesel Hercules is a DJX* engine. Last letter* is the difference in bore size. Can you describe the engine a little bit better? Where are you located? I will also send you an e-mail
