Lesser Known Classics Discussion Forum
Intercontinental CF26
mikentexas
11-04-2006 12:15:13
I bought a 3 wheel tractor recently that I'm told is an Intercontinental CF26. It has an L-head 4cyl.continental engine. Needs a lot of work. I plan to try & restore it & would appreciate any info or links to it.
Thanks
Hardydr
11-23-2006 14:00:49
 Re: Intercontinental CF26 in reply to mikentexas, 11-04-2006 12:15:13
The Nov/Dec 2006 ANTIQUE POWER magazine has a LAUGHLIN C-27 on the cover. The article inside mentions the INTERCONTINENTAL C-26. Can anyone tell me the connection between these tractors and Marshall, TX? I live near Marshall.
mikentexas
11-08-2006 18:57:16
Thanks for the info, will ck.it out!
Fern(Mi)
11-08-2006 17:14:44
Engine parts should be available. Continental engines were used in everything: Tractors, cars, trucks, compressors, welders, generators, boats and whatever I failed to mention. They’re still a lot of them engines around. A good parts man (likely an older generation gentleman) should be able to find and order the new parts you may require. I apologize I can’t offer more help. It has been awhile.
Fernan
Fern(Mi)
11-08-2006 17:14:38
Fernan
noncompos
11-07-2006 21:32:24
More info (from Texas) if that"s a Texas unit (the pix I saw were of dual front wheels, not a single front wheel):
Gasenginemagazine.com: search Intercontinental C-26, a nice article should come up.
Google advanced search (exact words): Southern Aircraft Company. Four or five hits down will be "coachbuilt.com"...click on it and a nice piece, giving history of Intercontinental Co (out of Southern Aircraft Company) should come up.
But no parts help...Good luck.
noncompos
11-07-2006 13:13:26
If that's the Intercontinental Mfg Co of Garland or Marshall, Texas, that engine is probably a Cont F162, a very popular engine of the time. Specs, etc will be in any Motor Trk/Tractor manual covering late 40's (in the engines section under F4162 and in the Massey-Harris section under F162).
Intercontinental of Texas had a C-26 model,46 or so to 56 or so per the tractor books; no CF was listed but the listings weren't intended to be complete (there was a diesel DF). No ideas as to parts, etc. Seems to've been some name changes or mergers; might--repeat,might--have been marketed as Sollberger, Laughlin, Nateco or Nateco-Laughlin. Good luck.
