Lesser Known Classics Discussion Forum
BF Avery A Timing ?s
Tonybackache
12-24-2006 18:23:09
This tractor will run but barely. Throttle won't advance without smothering. I'm thinking the engine time is wrong because Fly Wheel (we have never broken tractor into, but before us who knows?) or some other component have been installed wrong. Which would make correct timing of engine impossible.
Even after fresh Over-Haul, New Carb, New Manifold, new points, plugs & wires, Rotor cap & button, & other stuff I can't recall. Tractor runs no better than before anything was done.
Several reputable mechanics haved tried to make it run correctly without success.
Averyman
12-26-2006 09:01:03
 Re: BF Avery A Timing ?s in reply to Tonybackache, 12-24-2006 18:23:09
Many times the tractor comes for sale because previous owner messed it up. Could be more serious like camshaft timing, insufficient valve clearence, bad head gasket, etc. Do a compression test, it will help you pinpoint the problem and maybe even tell you whether or not its even worth monkeying with the engine.
Larry from md
12-25-2006 15:08:32
Do you have a magneto or distributor? Both are timed to fire tdc static timeing. When running the timeing advances.You impluse or advance in the distributor may not be working. Could other tings too.
Tonybackache
12-25-2006 15:15:37
 Re: BF Avery A Timing ?s in reply to Larry from md, 12-25-2006 15:08:32
Distributor.
Tonybackache
12-25-2006 15:19:59
 Re: BF Avery A Timing ?s in reply to Tonybackache, 12-25-2006 15:15:37
Forgot to mention Distributor was changed out with a used one from Mr Williams' Salvage Yard in MS. No difference after the change.
J Schwiebert
12-26-2006 04:44:42
 Re: BF Avery A Timing ?s in reply to Tonybackache, 12-25-2006 15:19:59
I also send you an e-mail on using a vacuum gauge. Did you get the e-mail? J.
Tonybackache
12-26-2006 13:51:05
 Re: BF Avery A Timing ?s in reply to J Schwiebert, 12-26-2006 04:44:42
I didn't receive e-mail concerning Vacuum gauage.
New headgasket was installed during over-haul.
J Schwiebert
12-27-2006 05:36:33
 Re: BF Avery A Timing ?s in reply to Tonybackache, 12-26-2006 13:51:05
I tried it one more time. I need your phone number and e-mail address and then we can discuss it. J.
Larry from md
12-25-2006 18:07:24
Looks like i messed up the typeing in the other post. It could be the carb or manifold allso, its hard to solve from afar.
