Lesser Known Classics Discussion Forum
1940 Silver King Shifter
Bill Copeland
01-01-2007 15:54:23
I have way too much play in the shift lever. Is the problem wear at the bottom end or wear around the ball swivel? Where do i start to troubleshoot this?
tractor Hank
01-30-2007 19:01:52
 Re: 1940 Silver King Shifter in reply to Bill Copeland, 01-01-2007 15:54:23
I have a 1938 small three wheeled Silver King with the same problem, so let me know if you find out how to fix it and give me a call 785-748-0061. Thanks, Hank
Larry from md
01-02-2007 09:58:57
The SK shifter is much like the allis WC shifter and ends up with lots of play. They both use a small bump of metal on the case with roundish half hole in the shifter. You can pull the parts and weld them up and grind to size, but they will wear loose again.
