Lesser Known Classics Discussion Forum
Burns Outdoor Power Equipment
steve98604
02-12-2007 09:17:36
I have an old Burns Outdoor Power Equipment rototiller that I need to find the original pulley and belt sizes. It seems to run fine, but I can't find the correct length belt so I think someone put the wrong size pulley on. Any help on finding who or where to contact would be appreciated.
Gene Davis (GA)
02-12-2007 17:51:20
 Re: Burns Outdoor Power Equipment in reply to steve98604, 02-12-2007 09:17:36
Burns Tool and Die Works was in Lousiville,Ga.(30 miles away) in the 50's. They originally produced aluminum door and window screes. Then they began to produce direct and gear drive chain saws,using a West Bend 580 engine and the roto tillers using a Clinton engine. They made good tillers. The saws were ok for occasional light use. The fiber gears in the transmission didn't stand up under heavy strain and they were a one design saw which did not get lighter as did everybody else's design. They eventually were bought out, can't remember who now. After all it has been 50+ years now. The last tiller I worked on made by them. I replace the engine and just found a belt at the local hardware store to fit it. There is no one left to ask all records are long gone !
