Lesser Known Classics Discussion Forum
dx 120 deutz
charley c
03-06-2007 18:31:28
have a dx 120 deutz. unit started puking out a lot of blue smoke at the exaust. and finally puking out a lot of oil at the exaust, unit is non turbo. starts and runs good doesnt miss. seems to have good power. could i have fried a valve guide seal? maybe a scored piston? thanks
rongrong
03-12-2007 20:48:16
 Re: dx 120 deutz in reply to charley c, 03-06-2007 18:31:28
the bushings and shafts in the valve rocker arms might be worn and oil is flooding the valve chamber, or the screw in the rocker is letting to much oil past. if the engine has around 8000 hours or more then i would go for the bushing repair trick.. on my 160 this cured it for around $200.00 10 years ago..
Deutzilla
03-12-2007 14:32:01
Just because it is black does not mean it is oil. If the tractor has been not running under full load I would say it is unmburnt fuel. Have seen it many times in our Deutz and IH tractors. Cover the fan ALMOST all the way and get it hot. It should clean itself up.
richard in nz
03-10-2007 02:04:58
Check for dripping injector(s)
no deeres here
03-07-2007 18:23:27
Has this tractor by any chance been doing a lot of sitting around idling and not getting heated up. We had same problem years ago with our Agco Allis 5670(also air cooled). We just couldn't get it warmed up and after a while got dark smoke and tar coming from the exhaust. Mechanic told me to cover the fan with a plastic bag a run it hard until the thing was almost ready to overheat then remove the bag and run it some more to burn the tar out. It did the trick and now in cold weather we always restrict air flow and watch the gauge.
charley c
03-08-2007 04:38:11
 Re: dx 120 deutz in reply to no deeres here, 03-07-2007 18:23:27
smoke it blueish white and a lot of it and its not a tar type substance its oil running down the exaust. and a good drip drip drip when its running
