Lesser Known Classics Discussion Forum
Belarus 822 Help
John Wilkinson
03-16-2007 17:10:18
Any one have a copy of the electricl system of an 822 Belarus. I really need to know what the 12 to 24 volt switch is called, or what the part number for it is, or does anyone have a switch for my 822. It's located between the batteries and switches from 12 to 24 V to start the tractor. Also anyone know if there is a replacement part off of something else I could use instead of the original if I can't find one?
richard in nz
03-24-2007 18:56:13
 Re: Belarus 822 Help in reply to John Wilkinson, 03-16-2007 17:10:18
Don't be afraid to pull that black box to bits. Usually a clean up and bending of the contacts is enough to get those things going again. They are fitted to all sorts of things like Claas combines (Lexions in the States) my sons Nissan patrol has one as well. You can go 12 volt, Delco and Iskra make starters as up to 1988 the Belarus was 12volt anyway.
John Wilkinson
03-17-2007 14:40:27
Mine is has two twelve volt batteries with Positive Ground. Runs on 12, starts on 24.
Trkr
03-17-2007 10:00:08
 822 in reply to John Wilkinson, 03-16-2007 17:10:18
You can do away with the switch.There is an outfit in Texas that makes Delco 12 volt starters for Belarus's.We put one on our 820,starts just as good with the 2 12 volt batteries hooked together.Plus if you need the starter worked on again you can have it fixed at your local shop,the only thing on the starter thats Russian is the drive.
John Wilkinson
03-17-2007 14:37:50
 Re: 822 in reply to Trkr, 03-17-2007 10:00:08
That sounds like a good idea. Do you know how to get in touch with the folk in Texas who'er sell'n em?
John Wilkinson
03-18-2007 18:38:26
 Re: 822 in reply to John Wilkinson, 03-17-2007 14:37:50
Thanks a bunch. I shot them an email for information about this starter. John
Trkr
03-17-2007 18:44:33
Website is www.aabkelleyind.com. Just googled belarus starter texas and it came up.Also,check your polarity,every Belarus I've ever seen has been negative ground.
John Wilkinson
03-16-2007 21:50:19
Could I adapt this switch on ebay to work on it?>Link
John
Weldin man
03-17-2007 04:54:32
 Re: Belarus 822 Help in reply to John Wilkinson, 03-16-2007 21:50:19
Looks like this switch should work. Does your tractor have 6 or 12 volt batteries. I think the old Macks had 4 -6 Volts. Is the belarus positive or negative ground? You might have to change some wiring. I have worked on the Old B Model Macks and a Belarus or two but its been a long time ago and I just cant't remember.
Weldin Man
03-16-2007 19:28:22
I don't know what Belarus calls the switch,but we have always called them a Series-Parallel switch. They were pretty common on older models of road tractors, especially KW. It allowed you to have 12V lights, accesories and charging system and start on 24V. One of these probably could be adapted.
John Wilkinson
04-19-2007 16:32:35
 Re: Belarus 822 Help in reply to Weldin Man, 03-16-2007 19:28:22
What are the capacitys of the engine oil, trans and hydraulic oils for the Belarus 822 Diesel? Is there a good book with all this information in it?
