Lesser Known Classics Discussion Forum
Continental engine on propane
Tooler
04-01-2007 06:55:21
I have a small Clark forklift with a 4 cyl. continental engine on propane,suposidly its the same engine in a 101 Massey tractor,having a hard time starting it when it sits overnite, have to crank the starter for at least a minute, once started it will start instantly for the rest of the day,I dont know much of anything about propane, what should I look for.
Gene Davis (GA)
04-03-2007 19:51:56
 Re: Continental engine on propane in reply to Tooler, 04-01-2007 06:55:21
Does this engine have a primer button on either the dash or the regulator? This is used to supply a small amount of propane to enter the air stream for cranking like a choke on a gasoline carburetor. After engine starts, it usually is not needed till engine gets cold again like overnight.
