Lesser Known Classics Discussion Forum
Silver King help...
arthur
05-04-2007 03:07:20
Looking at a 36 silver king S/N 1033 with a patent #D91855..What model is this? Has a 1XA motor, wide front...Needs a new front rim...Are parts stil available for this tractor? It also has a front hydrolic snow plow. Has the hyd. pump running off of where the belt pully goes, and also has a generator running off of the same set-up...Guy said it used to have a roof, w/ lights on rhe roof...but the rooh/lights are gone now, so as far as I can see there is no need for the gen. Thanks ...Art
noncompos
05-04-2007 09:45:58
 Re: Silver King help... in reply to arthur, 05-04-2007 03:07:20
Apparently several Silver King models used the IXA, but you should be able to find help, or at least sympathy, at silverkingtractors.com. Good luck
arthur
05-04-2007 06:46:15
This tractor doesn't seem to have provisions for a starter, does that make it a 10-20?
