Lesser Known Classics Discussion Forum
HUBER Maintainer HELP, Please
Oldfarmboy Jim
06-25-2007 23:42:47
Does anyone know what kind of clutch to order for a HUBER MAINTAINER, 6cyl.???
I heard that it was a pretty common size and make( like "the same one as used on a so-and-so truck" )
But that don"t help me much. Any of you county road employees up around Marion , Ohio will you scratch your heads and send me(ra5c@att.net) an e-mail on this??
Thanks loads.
oldirtman
07-05-2007 08:40:59
 Re: HUBER Maintainer HELP, Please in reply to Oldfarmboy Jim, 06-25-2007 23:42:47
I sent mine to South Bend clutch and had it the next day for less than 100 bucks....do not know where you live but BROWN can ship for you too ! 574-256-5064
Oldfarmboy Jim
07-03-2007 21:44:08
Thanks for the help. I"ll take the info around to a couple of shops and see if it lights any lightbulbs. Oldfarmboy Jim.
El Toro
06-27-2007 08:23:11
You can probably have your old clutch disc recovered. I had that done on a farm tractor.
You could contact Morgan Brake & Clutch at 1-800-667-4113. Hal
PS: Are there any names and numbers on the old clutch?
noncompos
06-26-2007 11:43:49
Wellll...FWIW: a 62 (copyright) Lipe-Rollway clutch catalog lists two Huber-Warco Maintainers: Model M52, years 53-60 with a Herc QXB, and the same model, years 56-60 with either a Cont F162 or a Cont GO-157. All show with a Lipe 120-1-361 Cover Plate Assembly, a Lipe 120-6-129 Driven Disc assembly, a Lipe K25 facing kit, and spline size 11/2-10...In their numerical list the 120-1-361 shows against 19 trks, cranes, etc., while the 120-6-129 shows against 22 others, and not always the same ones (each list has some omitted from the other (!!). (Anomaly: There's a Borg-Warner and Accurate interchange list, but neither of the above are on it)??. The most familiar names on the Plate list are Diamond T, Federal, FWD and Reo; on the Disc it's the same incl IHC and Mack. If nothing more definite turns up I can email some of those truck models. Good luck!
