Lesser Known Classics Discussion Forum
Hydraulic/transmission fluid in Long (Landini) R9500 98hp
Archie_LA
08-07-2007 16:28:57
Need help on fluids for Long (Landini) R9500 Special tractor with 98 hp 6.354 Perkins diesel. I have put about 5 gal of "303" transmission/hydraulic fluid in a side port near where the transmission is labeled "livello." There were two drain ports that emptied this fluid. I am not sure but it may be that the hydraulic fluid is separate from the transmission fluid (it seems cleaner where it seeps out of a remote connector). If it is separate, and the only fluid going through the hydraulic pump in front of the engine, then would it be ok to put in "R&O" Iso 32 hydraulic fluid into the tank mounted on the side of a rear fender which is connected by hose to where the hydraulic fluid seems to go? If not "R&O" would you use "303" in the hydraulic fluid reservoir? I have not seemed to locate where the hydraulic fluid drains. Perhaps it does empty into the transmission area. But my current guess is that these fluids are separate. Also I wonder what to put into the power steering reservoir.
Thanks in advance for any opinions. I don't yet have a manual for this tractor.
