Lesser Known Classics Discussion Forum
Power steering
Dave (Milan, Mi
08-24-2007 09:14:43
I have a Ford 1841 with aftermarket power steering. It has been using what looks like a stock power steering pump for fluid supply but the mounting of the pump is all screwed up. I think it has either the wrong pump bracket or wrong pump. Anyone have a good close-up picture of the pump on one of these?
Alternate: I was going to just plumb it into the hydraulic system with a priority valve and junk the p/s pump. But, Jackson Steering doesn't answer their phone 620-357-6546 so I'm not sure how to do that or where to get a priority valve. Advice?
geok
08-24-2007 19:39:33
 Re: Power steering in reply to Dave (Milan, Mi), 08-24-2007 09:14:43
Not a good idea with a ford. GPM is already low and you would have to put a relief valve on to bring pressure down from around 2000 to 1000, 1200. Should be easier to fabricate a strong mounting bracket for existing P/S pump. My 1 1/2 cents worth.
