Lesser Known Classics Discussion Forum
Davis task force 300 trencher
ryanj
08-29-2007 14:17:40
For Terry H
I saw your message on Yesterdays Tractor Forum about your Davis task force 300. I recently purchased an old farm and discovered the same trencher behind the barn. I am trying to get it running, but the battery is missing, and without a manual I cannot even tell if it is 6 volt or 12 volt. If you can tell me what size battery your uses, or even just what voltage I would be very grateful. Also, how many pages is your manual? Would you be interested in photocopying or scanning it for me? (scan and e-mail preferred). If so, how much could I pay you for the trouble of doing it?
Thank you very much
Ryan
Winters, CA
Paul Selinger
10-30-2007 17:28:04
 Re: Davis task force 300 trencher in reply to ryanj, 08-29-2007 14:17:40
I have the manual for a Task Force 300 if your still interested Ryan? I"ll bring a copy home with me by Nov 7/07 and send it to you if you like.
noncompos
08-30-2007 07:31:38
A couple suggestions on the 6V-12V question:
If it has any lights, pull a bulb; they're all marked. If you've been around 6V stuff, you'll remember the "fatter" wiring--6V needed heavier wire; the 12V wiring is generally much skinnier. Good luck.
El Toro
08-29-2007 19:02:01
Look on the Trencher for a generator and get the model number. May be able to tell the voltage. Hal
ryanj
08-30-2007 12:27:10
 Re: Davis task force 300 trencher in reply to El Toro, 08-29-2007 19:02:01
Hal
GOOD IDEA! I am now guessing it is a 12 V system since the number is A12N-451. Also looks more like an alternator than a generator.
Thank you for the suggestion.
Also hoping that Tom (or anyone else) will see my question and let me know about a manual I could pay them to copy.
Ryan
El Toro
08-31-2007 05:57:41
 Re: Davis task force 300 trencher in reply to ryanj, 08-30-2007 12:27:10
Try Manuals.us or call them at 1-866-526-6568 or email them at info@manuals.us Hal
PS: I played baseball at Lewisville, PA where these manuals are located many years ago.
ryanj
08-31-2007 06:51:53
 Re: Davis task force 300 trencher in reply to El Toro, 08-31-2007 05:57:41
Hey Toro
Thanks for the lead on the manual!
Ryan
