Lesser Known Classics Discussion Forum
Huber HS
Sloroll
09-03-2007 16:32:07
third party image
What is the correct Carb for a 1935 Huber HS? Where can I find one and Where can I find a head gasket for the same? I may be in need of various other small parts too. Any Huber parts men out there?
Red460
10-07-2007 03:09:36
 Re: Huber HS in reply to Sloroll, 09-03-2007 16:32:07
The tractor is beautiful. The Huber HS has a waukasha CHS engine. It is not the same as Oliver 80 (Wauk. VIK engine). The Huber HS is the same chasis as Huber HK but the HS has a smaller bore and stroke. Huber HS/HK run very well; Great engine.
noncompos
09-04-2007 21:05:55
Forgot to add the Huber Museum (Huber Machinery Museum?) in Marion, OH, where they were built, can probably tell you how to ID the engine, what carb goes on and maybe suggest parts sources(phone was 740-387-9233 a couple years ago, and a Brent used to post Huber info; said he was on the Board); once the engine"s ID"d olsonsgaskets.com (Port Orchard WA) seems to get a lot of good mentions for old stuff (someone said they were closed but their website was on a week or so ago). I have a few Wauk parts refs from other sites if nothing else turns up. Good luck.
Sloroll
09-04-2007 21:17:59
 Re: Huber HS in reply to noncompos, 09-04-2007 21:05:55
Thanks for all the help! Bill
chparks
09-04-2007 17:13:31
I have a 1942 Tractor Field Book. It shows a
Huber HS with 4 3/4 bore and a Zenith carburetor.
No number
The Oliver 80 it shows 4 1/4 bore and a Schebler
carb.
noncompos
09-03-2007 23:11:21
This may just confuse things, but:
Bearing catalog shows Huber HS 1934-45 with Wauk CHK/CHS...but they"re lumped in with others for which no 43/4x61/4 is shown (closest is 43/4x 63/4).
Motor manual shows Oliver 80 38-48 41/4 and 41/2 x51/4, but 90 and 99 38-49 (end of book) have 43/4x61/4...with sympathy, Bud
J Schwiebert
09-03-2007 17:55:22
Is that the same basic engine as the Oliver80?
Sloroll
09-03-2007 18:44:43
 Re: Huber HS in reply to J Schwiebert, 09-03-2007 17:55:22
I think maybe it is.. not sure. It is 4 3/4 X 6 1/4 Waukisha with a Ricardo L head.
Sloroll
09-03-2007 16:34:34
third party image
