Lesser Known Classics Discussion Forum
550 long hyd pump hot
deene
10-22-2007 15:12:48
got my dads 550 long running last sat and while using it to brushog i noticed after an hour or so of running that the housing on the front of the motor that the hyd line runs from was smoking from the grease accumulated on the outside of it what do i need to look for as far as problems..the 3 pt was down so it really didnt have a load on it as far as i know..any suggestions..thanks
Tradititonal Farmer
10-27-2007 03:09:55
 Re: 550 long hyd pump hot in reply to deene, 10-22-2007 15:12:48
Fiat owns the UTB plant in Romania and many of the Italian Fiat built parts are the same as the UTB built parts.
marlowe
10-25-2007 15:22:34
what do you call hot? all hyd pumps will be hot. guys will come in to the shop and say things are hot but 99% of the time it's normal only way to realy till is use a laser thermometer 180 225 250 is not hot for a hyd pump see them temps all the time and some higher
deene
10-29-2007 21:20:25
 Re: 550 long hyd pump hot in reply to marlowe, 10-25-2007 15:22:34
didnt get the temp as i dont have a laser but excess oil and sludge on outside of the housing started smoking and havent seen that on any other tractor so i figured it was more hot than need be..went and checked it this weekend and it was low on fluid i guess didnt see a dipstick or where to check couldnt reach oil with finger in the housing so i added a gallon and havent had a chance to run again..thanks for your input
RMinVa
10-23-2007 18:46:32
Sounds like it could be the relief not opening. It should put a little strain on the engine if so. Also check the remote valve lever and make sure it's not stuck in the up or down position. If the spring is broken in the lever(and is down) for the remote it'll be pushing pressure against the ball in the coupling for that side of the valve. If it got very hot it may have cooked the hydraulic oil also. It may need changing now and hope it didn't do harm to the pump.
J Schwiebert
10-23-2007 10:30:27
Is this a Fiat design tractor. Will the 3 point arms raise?
deene
10-25-2007 14:25:35
 Re: 550 long hyd pump hot in reply to J Schwiebert, 10-23-2007 10:30:27
yes everything works as it should and brushogged with it for some time before the housing started smoking so dont know what happened will check and see if remote lever is stuck or not and i dont think its a fiat as it doesnt have a french motor in it..thanks for your help guys
J Schwiebert
10-26-2007 20:40:37
 Re: 550 long hyd pump hot in reply to deene, 10-25-2007 14:25:35
Fiat is Italian. The Longs or at least some of them were Fiat copies made in another country.
