Lesser Known Classics Discussion Forum
Harris Power Horse PH40
Dave In Mass
11-05-2007 20:17:41
I can"t seem to get the steering to work on this machine. The tractor has been sitting for the last three years or so and was operating fine when it was parked. I"m not sure if the clutches are stuck. I raise the tractor up with the blade and backhoe and put it in high gear and raise the throttle, and when I pull on either of the steering levers it nearly stalls the engine and the wheels don"t stop or do anything. I played with with the brake adjustment (what I thought was tightening) to see if I could get the planetary gears moving and reverse that way but now I have no brakes at all. I"m not sure what I did or why this happened. I put the adjustment back to where it was but I still have nothing. So now I have a tractor that drives backward and forward constrained between a telephone pole and stone wall. I"m going nuts, does anyone have any experience or suggestions on what to do. The pieces are so big its not an east thing to just take a wheel off and get into the clutches. I can manuver direction a little with the backhoe but not well.
Thanks
Dave
