1> Thankyou for the replies from cskent; noncompos; and H.J. Durham.2> I would"ve reposted earlier but I am overwhelmed by life because of 4 episodes of brain damage, with its numerous, awful effects and resultant chronic fatigue, sleep apnoea, migraines, and multiple sclerosis, plus arthritis and a further overwhelming struggle against the continuing evil done to me by others. 3> The person, from whom I purchased the Payloader, had told me the label was removed or the data rubbed off. I went over the machine and found some information, including the aluminum label on the left, inside of the cab, near the top edge. Some of the top edge of the tag had been torn off, but the "IH" combination symbol is clear and part of the "International Harvester" name can be presumed. 4> The parts where he thought data was worn off were just blank areas. The top area, which I don"t know how he missed, shows, clearly enough, "H-25B 3843030008980". The "38" may be "3S" but I think "38". The number is followed by a symbol that may be an ampersand, "&". At the bottom of the tag, it says "Made in Canada". 5> I can"t find a name on the motor, but on the exhaust manifold, facing towards the centre of the motor, looks like the "IH" combination symbol. Upside down, with a long space between the "IH", what may be the number, "308988RI". I"m not sure the 3rd number is an "8", less sure the 4th number is a "9", unsure of the "88", nor if the last digit is a "1" or an "I". 6> On the fuel pump/injector, I gues it is, there is a label saying, "ROOSA MASTER", below that, "DBGFC 431-1EG 2200" above "Model and RPM". The next line says, "Z3Z7079 702376-C92", above "Serial # & Mfg". I"m not certain the last group isn"t meant to start with "232" rather than "Z3Z". 7> On the left, front side of the cab, there are decals saying "PAYLOMATIC"; below it, "cae", a vertical stroke and "m", "Sales & Service"; and "cae - MORSE LTD". 8> On the right front side of the cab, there is a stylized "h" with a pennant shape pointing left off the top of the "h", and the remnant of a "25", without obvious evidence of a "B". 9> I haven"t had time to follow the suggestions from the replies I have received but this latest change of data may prompt different offerings. Robert.
