Lesser Known Classics Discussion Forum
UTB 445 and Fiat parts Crossreference
Darko
12-14-2007 10:33:25
Can anyone help on parts cross reference between UTB 445 and a Fiat tractor model. I have a retail tractor parts shop in Macedonia, and when I wish to buy parts from Turkey they only have listed FIAT tractors parts and OEM numbers. I know the engine should be same with FIAT 450 (95mm piston)but someone mentioned that the diferential and other parts are different. Does anyone have an advice? Thanks.
Pycoed
01-13-2008 13:40:00
 Re: UTB 445 and Fiat parts Crossreference in reply to Bus Driver, 12-14-2007 10:33:25
Eamon Kearney said: (quoted from post at 12:52:00 01/10/08) Hi, I have a universal 445 dt (4 wheel drive model).
I live in Northern Ireland.
I wish to replace the heater plugs which I am told were part of an upgrade kit.
Does anyone know what part numbers they are and where I could buy them.
Hi Eamon,
I'm from West Wales & also have a 445DT. As far as I am aware, they were all fitted with a "Thermostart" rather than heater plugs. This is the same as fitted to David Brown & some Fords of the same era (mine is 1976).
It is a small heater coil with a diesel reservoir about the size of a 35mm film case screwed to the inlet manifold. The reservoir fills from the leak-off pipes & when the coil gets current it heats up to red hot, opens a valve which drops the diesel down onto the coil & heats up the manifold. If you feel the manifold after powering the Thermostart, it'll feel hot. Then it should start OK. Ther should be a position on the start switch that energises the Thermostart before the starter engages. Check that this actually happens - I've put a warning light on mine so I know its heating. I use about 60 seconds of heat if its down below freezing & it starts within 5 seconds of turning.
I checked my Thermostart & it was OK, once I'd fixed the terminal back on!,but I got a spare from Ebay - about £10 & they were widely available, but you may have to change the terminal type for the electrical connection - spade or screw.
Larry59
12-26-2007 13:41:57
 Re: UTB 445 and Fiat parts Crossreference in reply to Darko, 12-14-2007 10:33:25
Romanian tractor is correct. I have the 610 DTC Long . Gauges show Romanian on each one. Mine is 1985. Long sold out in 1998 to Farmtrac. Understand they change the name to their own on them.
Larry59
12-20-2007 20:19:01
I have the 610 4x4 diesel here in Missouri USA. Farmtrac tractors bought out Long here in 98. Perhaps this might help you in searching.
oops.. had a 620 on it.. shessss 610 Long is correct. Sorry
Larry59
12-20-2007 20:18:02
I have the 620 4x4 diesel here in Missouri USA. Farmtrac tractors bought out Long here in 98. Perhaps this might help you in searching.
Pycoed
12-17-2007 15:36:26
 Re: UTB 445 and Fiat parts Crossreference in reply to Dave Sherburne NY, 12-14-2007 10:33:25
Darko said: (quoted from post at 20:33:25 12/14/07) Can anyone help on parts cross reference between UTB 445 and a Fiat tractor model. I have a retail tractor parts shop in Macedonia, and when I wish to buy parts from Turkey they only have listed FIAT tractors parts and OEM numbers.
Thanks.
They were sold as Long 445 & Allis Chalmers 5040 in the USA so you may have better luck asking for those?
I'm in UK & have an UTB 445DT - thats the 4WD model
Eamon Kearney
01-10-2008 02:52:00
 Re: UTB 445 and Fiat parts Crossreference in reply to Pycoed, 12-17-2007 15:36:26
Darko Serafimovski
12-21-2007 00:44:07
thank you for your help. I will try a search otherwise.
VLAD
12-26-2007 12:26:03
 Re: UTB 445 and Fiat parts Crossreference in reply to Darko Serafimovski, 12-21-2007 00:44:07
It seems to me to be a Romanian tractor you may try www.utb.ro if that is the case.
