Lesser Known Classics Discussion Forum
Wain Roy Backhoe
Gus Demetriades
01-30-2008 17:32:01
This message is a reply to an archived post by Tony Socci on August 10, 2003 at 05:38:17.
The original subject was "Re: Re: Re: Re: Re: Wain Roy Backhoe".
Any body know anything about Wain Roy Backhoes? I have one and the rear end has issues anybody know where to cross reference parts for the rear end Specifically rear end imput shaft for the axle(bearings). Thanks for any help I have not been able to find anything so far.
Das Unimog
01-30-2008 19:28:23
 Re: Wain Roy Backhoe in reply to Gus Demetriades, 01-30-2008 17:32:01
Gus, do you know what model? If it has the Ford
4 cyl engine then it is probably a Rustler like
the 2 I have. The tractor is basically made up
from Ford parts. If you have this model, it is a
Ford banjo rearend with drop reduction at the wheels. Cross reference should be around a 1950
to 53 Ford truck, size maybe the F2 or F3 pickup.
A good truck partsman at a Ford dealer should be
able to research some info for you. If you have
a "jimmy" engine then you're looking at a totally
different animal and I can't really give you much
help. Unimog
