Lesser Known Classics Discussion Forum
Belarus 825 3 point inop.
Joe Prince
05-19-2008 05:43:25
The 3 point will not raise, the loader and HYD remotes work OK.
Joe Prince
05-23-2008 18:26:17
 Re: Belarus 825 3 point inop. in reply to Joe Prince, 05-19-2008 05:43:25
Got it fixed this PM!! I removed the 3 point lift cylinder, the big nut that held the piston on had came off. Had to remove the seat, loosen up the L/H fuel tank. I will start cutting hay with it in the A.M.
Thanks for your help Joe
richardinnz
05-21-2008 04:34:37
Have you got a height limiter on the rear lift ram? If so check the limit stop on the ram has not slid down, or that the pin on the valve on the ram has not stuck in, not all Belarus have them, but a lot do.
Joe Prince
05-23-2008 11:35:59
 Re: Belarus 825 3 point inop. in reply to richardinnz, 05-21-2008 04:34:37
The pin I found was on the back of the ram, is their one on the forward end? If so that is the end that dose not move. The old tractor has a cab on it and is hard to see.
Thanks Joe
Joe Prince
05-21-2008 06:11:22
I will ck it this PM Thanks Joe
Joe Prince
05-23-2008 06:50:43
 Re: Belarus 825 3 point inop. in reply to Joe Prince, 05-21-2008 06:11:22
Richard,
I removed the pin at the back of the cylinder, cleaned the valve and re-installed. I tried to rase the 3 point with this pin in all stages from full out to full in. I do now have down fource but no up. Thanks Joe
