Only one known in existence! Need help!
Mike
08-07-1999 02:24:47
I have a Baylor tractor, gas engine, probably manufactured in the late teens or early twenties in Iowa. Ever hear of this make or have any information at all? It was thought that there are none left, but I have one! I can't find information for it anywhere. Any help at all would be greatly appreciated.
Dwain
08-25-2000 21:27:55
 Re: Only one known in existence! Need help! in reply to Mike, 08-07-1999 02:24:47
I was looking through your add and found it interesting. I was curious as to how your situation turned out. Have you found out any more info about your tractor? It has been a year and hopefuly you are not still searching. What condition is your tractor in, after all you said it was manufactured in the early twenties.Do you still have it?
You can respond to "littlebearfarm@aol.com"
Tom from Ontario
08-07-1999 20:41:21
Mike: C.H.Wendel has a note on tractors built by the Bailor Plow Mfg. Co. but they were in Atchison, Kansas and built two models of tractor from 1919 till the early 30's. He says they were more a motor cultivator than a tractor because the seats were real low, like there is no way from the picture you could see past the engine. 4 cylinder Leroi engine he says. Don't know if this helps at all. Tom
Dwain
09-14-2003 17:13:48
 Re: Re: Only one known in existence! Need help! in reply to Tom from Ontario, 08-07-1999 20:41:21
Did you ever get any info on the Bailor?I'd like to talk to someone about it. Thanks, Dwain
