Rumley Oil Pull fuel pump
Petcock
11-20-1998 11:41:09
My M 20-35 Rumley Oil Pull has quit pumping fuel from the keresene tank to the carburetor. The check valve in the tank is good, and the fuel lines are ok. I'm wondering if the pump plunger in the carb could be causing this problem. Does anyone have experience with these Secor-Higgins carbs or any other usefull ideas about this problem?
