1940 A Farmall (Instructions To Attach Cultivator)
JH
09-08-1999 09:53:14
Looking for instructions for installing cultivator on 1940 A Farmall
Francis Gregory Biss
04-12-2003 19:35:01
 Re: 1940 A Farmall (Instructions To Attach Cultivator) in reply to JH, 09-08-1999 09:53:14
Instructions on how to attach cultivator to this farmall cub built in 1939. Please!
farmer mike
09-12-1999 11:17:00
for the cultivators i have, there is a square tube at the front of the cultivators. you put this in a square tube right behind where teh steering shaft goes into the steering box. then you put this rod with a spring on it up and onto the thing that goes up and down when you move the lever. id teh lever isn't mounted, i can't help you till i get my pictures developed and scanned. hope this helps a little bit. what is you serial#? mine is FAA23306
