Anybody Know About A Whizz Witch Weedeater
Nathan
10-11-1999 20:42:56
It is orange and white and built heavy like it might be an industrial model. It says Whizz Witch manufactured by Hoffco. I need a carb needle that's made of plastic. It will run for a second or two on ether. The needle is broke off at threads. I got it out but, thought maybe if I had a new one I could get it to run. Local mechanic said carb looked like Tecumshee but could not find a match. Thanks, Nathan
Dave Peiffer
05-06-2005 11:28:50
 Re: Anybody Know About A Whizz Witch Weedeater in reply to Nathan, 10-11-1999 20:42:56
Did you find a source for Whizz Witch parts? I have a Hoffco WW 850 that has had very little use and I'm am looking for the string guides for the head. They are aluminum pieces that fit in the head and the plastic cutting string goes through them. The P/N is 205510S.
Jeff Banzhoff
06-01-2004 17:21:00
They are a wonderful tool for clearing brush and small trees with the blade attachment. I知 all so looking for some miscellaneous parts. If I find them, I値l let you know.
Jeff
David Wilkins
06-13-2004 19:25:59
 Re: Re: Anybody Know About A Whizz Witch Weedeater in reply to Jeff Banzhoff, 06-01-2004 17:21:00
I have a complete engine from a 3 horsepower model, found it in a junked car, runs great, I was curious to what it was for, powerfull litle sucker! I may fabricate it on a scooter for my son or do something else constructive with it, the chances of finding the shaft and other parts are probley grim, anybody have one with a blown engine???
Bob
06-06-2001 22:42:53
Hi Nathan,
I doubt if you are still interested; but, just in case. I have a Whizz Witch and the following is listed for the Carb:
Tecumseh Engine Carburetor No. 631963
The Part Number for the repair kit is: 631893
