HOLDER TRACTOR
C MOORE
10-20-1999 14:04:28
Looking for somebody with a German made Holder tractor . Iam having problems getting the injector pump timed. This is an A M 2 two cyl. 2cycle disel. I know they still import in to Canada but they are no help on this 65 model tractor.
Merv Lloyd-Jones
01-14-2004 03:10:44
 Re: HOLDER TRACTOR in reply to C MOORE, 10-20-1999 14:04:28
I have 1973 A15 Holder Tractor 2cycle diesel and I am trying to buy parts for it(Piston,Rings,Conrod Bearings)without any luck.I live in Australia and thought somebody may be able to help or know of a Dealer.
Regards,
Merv
Chris
01-04-2002 19:17:46
I recently acquired a Holder A15 (serial #111446) Have already done a lot of work on it, but really need a owner/operator manual. Have tried just about everything trying to get hold of one, my biggest question being how to bleed the injection pump. I'd appreciate any help that anyone can give me...Thanks
Phil Sinclair
12-29-2001 23:52:01
Im searching for parts for a 1960 Holder.I have the manual.What site should I look at? I'm in New Zealand but am happy to look at importing.
Thanks,Phil
Mark Beban
02-13-2002 23:09:23
 Re: Re: HOLDER TRACTOR in reply to Phil Sinclair, 12-29-2001 23:52:01
Try Farm Services Te Puke 07 573 -0320. They are the dealers....
OMAR ABU EISHA
11-14-2000 10:00:44
LOKING FOR THE AGENCY EMAIL OR NUMBER OF THE GERMAN MADE HOLDER TRACTOR OR SELLERS OF GERMAN HOLDER TRACTOR.I NEED HOLDER TRACTOR FOR IT IS LOW SO THAT IT MOVES UNDER GRAPES FARM.
Rex Bales
01-14-2001 13:03:17
 Re: Re: HOLDER TRACTOR in reply to OMAR ABU EISHA , 11-14-2000 10:00:44
I have a HD-2 Holder tractor. It has a low compression on the front cyl. I am just letting it set now for the winter. It is not something I need but if I find the parts it need I will work on it as a hobby. It ran after I rebuilt the starter, installed a new battery, a new (off of a honda generator) self contained alternator, rebuilt both injectors, and a new fuel line to the pump.
I did not like running it with low compression on one cyl.. I have know idea what year it is.
Oregon Coast!!
Dave Wadge
10-27-2001 10:21:34
 Re: Re: Re: HOLDER TRACTOR in reply to Rex Bales, 01-14-2001 13:03:17
I just recently purchased a C15 holder tractor I am looking for information as the year also where I could get a manual , the tractor is in good running condition but has a few flaws
Rex Bales
01-14-2001 13:05:32
corrected email address
Ginette Gervais
04-11-2000 17:06:17
Looking for Holder Tractor 1987 manual for repair
I am located in Canada.
thank you.
Info:Dealer situated in Canada
Telephone (613) 821-4171
Facsimile (613) 821-1939
E-mail webadmin@holder.on.ca
Ed Weir
04-07-2000 10:37:09
I have a 1941 Holder w/2-cycle Sachs Diesel. This engine runs fine, and seems to be in good timing. I am NOT a diesel mechanic, but would be willing to help in some way if I can. I use the tractor for light garden work and to plow snow.
This is a very rare tractor - anything I can do to help?
- Ed.
Niels den Boer
04-14-2005 13:57:47
 Re: Re: HOLDER TRACTOR in reply to Ed Weir, 04-07-2000 10:37:09
Hi,
A little bit late maybe, do you have a picture of your Holder tractor? Maybe I can see what type it is.
Hope to hear from you soon,
Niels den Boer
Dr kamal Hassan
03-09-2006 15:00:59
 Re: Re: HOLDER TRACTOR in reply to Niels den Boer, 04-14-2005 13:57:47
Im searching for parts and manual for a 1964 A12 holder tractor. Please inform me by email if you can help me. Thank you.
Bruce Guy
10-19-2001 17:44:37
I have a Holder that I inherited from my uncle. It is such a neat piece of equipment. It has a tiller, a hillside plow (both of these are manufactured by Holder), a bush hog, a corn planter and some cultivators. The tractor had not cranked for the last seven years when I finally was given the unique Bosch key. At that time I had no instruction books, they were found two years later in perfect condition for a paperback that was printed in the early 60's. The manual and parts list was in four languages. I had figured out most of the controls and what to do to keep the tractor serviced prior to getting the manuals but it was great to know I was on the right track as I had used it guite a bit. I was amazed, after sitting for so long it nearly cranked off of the old fuel when I was just trying to find out where the starter was located. The first button I pushed which looked like a starter button, after I got the dirt dobber nest out of the key way, I learned was a horn! Amazing, about the time americans started putting roll bars on our tractors, the germans started putting turn signals on theirs...complete with a trailer plug under the seat. It is a pretty stout little tractor. the two cylinder unit, the AM-2 has 23 horsepower. Going through the 4 wheel drive of the same sized tires really allows the tractor to perform beyond normal expectations. Don't know if I can help anyone with any problems you may have but I will be glad to discuss it. Bruce Guy, Thomasville, NC
Dave Wadge
11-05-2001 16:19:43
 Re: Re: Re: HOLDER TRACTOR in reply to Bruce Guy, 10-19-2001 17:44:37
Re Bruce Guy; Holder tractor I have A15 Holder Tractor 2cycle diesel , The manual you spoke does it mention an A15 if so could you please contact me as I need to know a lot such as some of the controls, type of oil, I'm at a lost at how the oil goes from the filler tank to the crank As I have just purchased this gem Thank You Dave Wadge Kirkland Lake Ont. Canada
