try the link i have given you i only know a bit about isekis, the family farm own 6, at one time all the tractors on the farm were iseki they have isuzu motors, similar to what are found in most japanese diggers (4fb1,4bd1,6bd1 or something like that).these motors have bronze linings and go for ever, but when they do give problems they are expensive to fix.the 4fb1 is the same block found in the isuzu (holden, or GM) utes the small 18hp 2160HST had 3 cylinder Mitsubishi motors the range of models went from garden tractors to about 100hp, but that was only in certain markets, now they only produce up to about 60hp (due to the yen). traditionally good solid gear, has good reputation here in NZ, known as a bit gut-less, but hard to kill the big problem is parts, make sure you are sitting down when you price replacement parts,they are expensive i don't know if this is any use to you because i am in a different country to you. i am a bit rusty on remembering numbers so i hope i am close. as for the others, i don't even know what grey markets is, and yamnar is a subsiary of John Deere, which produces all of the compact tractors for John Deere up to about 60hp good luck
