Power King tractors
Tom-Tom
10-31-1999 12:31:18
Who knows where to buy parts ?
rick h
11-26-2001 18:41:42
 Re: Power King tractors in reply to Tom-Tom, 10-31-1999 12:31:18
where do i get parts for a power king tractor? in the chicago area e=mail herffjr@webtv.net
Glenn Stahlman
10-08-2001 16:07:20
I am looking for a power steering clyindar for my 1620 Hydrostatic Power King. If anyone can help me locate one I would greatly appreciate it. Thanks in advance.
Tommy Tucker
09-02-2001 13:52:50
Looking for clutch parts for a 1983 powerking mod:1217 SN:60593. I am in need of new clutch disc. and maybe a whole clutch complete(pressure plate front to back ) It is a six pin if that makes a difference. Can be contacted at 440-479-5858 any time thanks. T.T.
CCARSE
07-19-2003 21:34:30
 Re: Re: Power King tractors in reply to Tommy Tucker, 09-02-2001 13:52:50
I just acquire serial #60599..... ... would you have a visual of all factory grease zerk locations, and a visual of it's 42" mower deck zerks if any and the correct belt guard/s Thanks ccarse in WV
Frank Fogleman
05-31-2003 16:14:21
we also need parts. we need a clutch disk for a 74 power king 14 hp kohler HELP
Gary
08-02-2001 19:30:31
Could anyone tell me if there is an implement/attachments manual for the Power King Tractor, Model #2418?
D.Purkey
07-27-2001 15:58:19
Looking for a service manual for a 1975 Power King Economy Tractor, 41238 all gear. July 27,2001
D.Purkey
07-27-2001 16:05:31
 Re: Re: Power King tractors in reply to D.Purkey, 07-27-2001 15:58:19
Correction for e-mail address submitted five minutes ago. it should read AngiealaskaP@netscape.net. Requesting information on where a service manual can be obtained for a 1975 Model 41238 Power King Economy Tractor.
Buddy Timmons
04-09-2000 13:55:22
I am searching for mower blades for my Power King lawn mower. I have been searching the net and need to find these parts desperately if you can help it would be much appreciated. Sincerely, Buddy
Sara Stotts; Greig Memorial Library
07-21-2000 08:05:13
 Re: Re: Power King tractors in reply to Buddy Timmons, 04-09-2000 13:55:22
One of my patrons is in need of a part for a 1200 Series Power King Lawn Tractor. The Part
Number he needs is:60-0102 (adapter for blade.
The model number for his tractor is 60-042.
Could you help find where we can order this above mentioned part, or supply us with a telephone number or website where we can order? Any help will be most apreciated.
Mission Mfg. Corp
01-19-2001 08:53:31
 Re: Re: Re: Power King tractors in reply to Sara Stotts; Greig Memorial Library, 07-21-2000 08:05:13
We have many Power King patrs in stock.
We take Visa and Master Card.
812-385-5061
812-385-5977 fax
jones@sigecom.net
Frank Fogleman
05-31-2003 16:17:19
 Re: Re: Re: Re: Power King tractors in reply to Mission Mfg. Corp, 01-19-2001 08:53:31
i need a clutch disk for a 74 power king 14 hp kohler. can you help?
Jennifer
06-26-2001 18:38:44
I am looking for a power king tractor dealer in my area. Looking for the Pocono Mountain, Lehigh Valley area i the state of Pennsylvania. Thank you!
John Fosdick
04-06-2001 19:26:30
I have a 1966 Power King (serial#X12565E) It works great, but the hydraulic pump unit went out last summer. When I took it apart I found that the idler gear was broken in two the bushing worn out. The original part number for the gear was 4839 w/roll pin #1452. One dealer told me that the gear # was changed to PU 104, but he could not get it. When I called out to Economy they told me that the number was now #23-9033, but they no longer had it and referred me to another dealer who did not have it.
Does anyone out their have this gear or a usable pump? Please let me know.
Thanks,
John
Robert
04-03-2000 20:08:41
i am looking for information on hydraulic cylinders 31 1/2 inches from center to center hole closed and 24 inches open I have a power king tractor 1975 I bought it with a front end loader. the cylinders are bad I not sure what laoder is on it but the dimenions are listed.
Mission Mfg. Corp
01-19-2001 08:50:47
 Re: Re: Power King tractors in reply to Robert, 04-03-2000 20:08:41
We have any Power King parts in stock.
We take Visa or Master Card.
812-385-5061
812-385-5077 faz
jones@sigecom.net
L.T.Wilson
08-08-2001 12:04:23
 Re: Re: Re: Power King tractors in reply to Mission Mfg. Corp, 01-19-2001 08:50:47
Who manufactures Power King Tractors now. Do you have an estimate on the value of a 1985 tractor complete with 60" mower, disc and spring tooth harrows & rototiller? Is a snowblower available? Tractor has front end power takeoff. Any help appreciated !! Larry
Ed House
03-16-2001 18:01:09
i am looking for a plow for a 1979 power king 1618 can you help
RCOBB
10-31-1999 16:35:34
Give Crede Tractor Sales & Service a call
@ 304-965-1666 their mailing address is:
4731 Pennslyvania Av
Charleston WV 25302
You might also check out the Power King Home page @ yazookees.com and do a search for the
distributor in your area to see who might have
parts in your area.
Also there is a Power King Web page @:
http://members.aol.com/economy24/private/index.htm
Mission Mfg. Corp
01-19-2001 08:55:36
 Re: Re: Power King tractors in reply to RCOBB, 10-31-1999 16:35:34
We have many Power King parts in stock.
812-385-5061
812-385-5077 fax
jones@sigecom.net
sadsak
04-10-2000 10:52:35
Power King Factory is located in Tenn. They "800'# is as follows 1-800-262-1191. They are still making new tractors and have parts for old and new tractors.
Mission Mfg. Corp.
01-19-2001 08:58:07
 Re: Re: Re: Power King tractors in reply to sadsak, 04-10-2000 10:52:35
We have many Power King parts in Stock.
812-385-5061
812-385-5077 fax
jones@sigecom.net
RCOBB
10-31-1999 16:35:24
Charleston WV 25302
parts in your area.
