Satoh 550G
mike
12-08-1999 20:12:34
Do the Satohs come with a positive ground? Also do they run on 12 or 6 volt system? I thought 12 volts but i bought new battery(12v) and cables and connect the negative cable to the battery and then to the frame and then i connected the positive cable to the starter and then to the battery. When i did the starter started to smoke. What did i do wrong? Any help would be greatly appreciated.
Burrhead
12-09-1999 09:05:45
 Re: Satoh 550G in reply to mike, 12-08-1999 20:12:34
That should be on a 12V awright. If it started smoking just from hooking it up there is a short in the starter, or maybe the selonoid. and yes it is neg ground.
Mike
12-09-1999 17:09:47
 Re: Re: Satoh 550G in reply to Burrhead, 12-09-1999 09:05:45
Hey thanks alot there burrhead. I'll pull them parts off and see if they are shorted out and i might just go ahead and have them rebuilt. Thanks for the info, Mike
howard
03-16-2000 06:54:47
 Re: Re: Re: Satoh 550G in reply to Mike, 12-09-1999 17:09:47
good luck rebuilding the starter I understand that a new one is 2000 dollars from a dealer I talked to in Oklahoma Has anyone done anything with the hydrolic pump mine is leaking. Haven't taken it apart yet but was wondering if they are compatable with any others.
