Nuffield 10/60 Tractor (manual on hydraulics) or help!
Roger
01-01-2000 09:55:39
I have purchased a 10/60 tractor and am having some difficulty with the hydraulic system. The lever for the three point hitch seems to be dis-connected or loose. I have taken the top off the hydraulic system but can't see in to see if something is broken or not. Does anyone have any information for me. I need either a manual, pictures of what it should look like or verbal help. Is there a place where I can buy a manual? A quick reply would be appreciated if possible.
Laurie
01-06-2003 19:27:27
 Re: Nuffield 10/60 Tractor (manual on hydraulics) or help! in reply to Roger, 01-01-2000 09:55:39
Wife's Uncle just asked me to jump on the Net and find timing mark for Nuffield 10 60.
Could you give any clues to my email as I will probably not find this site again.
Thanks
Brian
01-02-2000 03:57:07
Roger,
You will not see much by removing the top of the lift. The whole back plate has to be removed to get at the linkage etc. This is not a bad job, I removed and serviced mine on a 4/65 which has more tin work, in 4.5 hrs.
The place to get a manual is B.Sims, 1 Hall Farm Cottages,Church Lane, Swarkestone, Derby, England DE73 1JB if one is not available from this site.
Regards
Brian
Roger
01-03-2000 16:49:23
 Re: Re: Nuffield 10/60 Tractor (manual on hydraulics) or help! in reply to Brian, 01-02-2000 03:57:07
Thanks for your information. Boy that's quick. Just a little info. I visited a tractor repair shop today near home. I found out that a previous owner removed the lever below the left side of the seat that engages the PTO, and hydraulic system. For what reason I don't know. They even removed the bracket that it slides in. I bought and installed a used one, started the engine and guess what? The darn'd thing worked. I am going to order a manual now. I appreciate all your help and your quick response. Have a Happy New Year and thanks.
Gordon Grieve
02-07-2004 14:56:12
 Re: Re: Re: Nuffield 10/60 Tractor (manual on hydr in reply to Roger, 01-03-2000 16:49:23
have an origional workshop manual if yo
u need info
Regards gordon 'n Libby
Peter GLASFURD
02-17-2001 23:24:45
 Re: Re: Re: Nuffield 10/60 Tractor (manual on hydraulics) or help! in reply to Roger, 01-03-2000 16:49:23
Require information on hydraulics system as fitted to Nuffield 460
