Country Squire Tractor
Paul
12-21-1998 07:16:09
Can anyone offer information on the country squire tractor?
Carlson, Andrea
11-18-2001 13:16:13
 Re: Country Squire Tractor in reply to Paul, 12-21-1998 07:16:09
Need to find out where I can get parts to repair/rebuild this type of tractor.
greene
03-08-2001 15:51:12
No it's not a ghost tractor. We have one, too.
It's a small garden tractor painted red. It has a
pull-chord start, a mower deck and needs a clutch. Otherwise its in decent working condition. Wish we could find a way to find parts!
Alan
07-06-1999 16:00:32
I have a Country Squire Tractor in perf. condition. 4 foot plow, 4foot mower deck, rear plow, umbrella& more. I would like to find out more about it.
Alan
07-06-1999 16:00:03
Tom from Ontario
12-30-1998 20:18:06
Paul: never heard of them other than Ford Station wagons. Could it be that you might be thinking of County tractors? 4 Wheel drive Ford conversions from England, usually all wheels the same size? Tom
Thomas Moje
05-13-2002 08:46:08
 Re: Re: Country Squire Tractor in reply to Tom from Ontario, 12-30-1998 20:18:06
I also have a Country Squire tractor. They were manufactured by Engineering Products Company, Inc. The same company that made Economy and Power King tractors. Mine has a 9-horsepower Wisconsin engine. Manual pull start (has the electric starter but needs a battery). Usually starts very easily. Also I have the original manufacturer single-bottom moldboard plow that was available as an accessory (as was a variety of ground working implements such as disks, cultivators, harrows, etc.) For that you need either the manual spring-assisted implement lift hitch, or the optional (and harder to find) add-on hydraulic implement lift unit. My tractor has the manual implement lift which works quite well. Also: if yours has the 3-forward speed geared transmission: it is common for these to lock in gear. Most often caused by worn out shims/bushings/detents inside the transmission. Just got mine overhauled for $75.00 which I found since was quite reasonable in comparison to what a rebuilt original equipment tranny cost (over $500.00). Anyhow they are a fun and useful tractor to have. Also they are small/light enought to fit onto a 4 x 8' utility trailer so you can take it to tractor shows without having to invest in a larger trailer/haul rig!
MAKurtis
05-31-2003 19:46:35
 Re: Re: Re: Country Squire Tractor in reply to Thomas Moje, 05-13-2002 08:46:08
Can you help?
My COuntry Squire 9hp was a factory re-build just two years ago and now it seems to have a real loss of hp. Starts fine, sounds good but luggs under load. Any suggestions as to what I should check?
