Unknown crawler
Pete Derrick
01-15-2000 21:51:17
I did some work trade for a woman whose brother had died. I found this great little critter in the back yard.It's a crawler about 5 ft long & 40" wide. The tracks are pressed 3/8" steel, the frame is 3" channel iron. There is no identification number or name, no transmission and it has a wisconsin hanging out front that just doesn't look right. I'm trying to send a picture but my computer skills are less than good. Anyway, if anyone could help with I.D.I would certainly appreciate it. My name is Pete, I'm at turtlerock@saber.net
ira strange
01-23-2003 12:25:58
 Re: unknown crawler in reply to Pete Derrick, 01-15-2000 21:51:17
From your description, you tractor sounds like one that I also have. Mine is a crawler, walk behind and also has the engine hanging out over the front. It has 2 handles(like the handles on an old horse drawn one-14 plow. On the right handle it has 2 levers which pushes plungers down into a chamber in the top of the transmission. On the other lever it has the throttle lever.If our tractors are one in the same. Your may also be a VAUGHN. VAUGHN MOTOR CO. Portland Oregon. If they are the same I may be of further help to you.
Let me know. Also I need parts for mine and LOTS OF WORK TO BE DONE ON IT. Ira Strange
blstrange@aol.com
andrew wright
09-19-2005 10:10:52
 Re: Re: unknown crawler in reply to ira strange, 01-23-2003 12:25:58
I have a crawler just like you said but it has been modifided into a small dozer and is fully operashonal, email if you still need help getting it running. andy in missouri
todd
02-03-2000 20:39:39
i thought i was crazy when i read this but i have found one that sounds exactly the same as the one you found your description is the same and i would also like info on this i am trying to locte the owner so i can find more info if i do i will contact you
todd
02-05-2000 22:14:16
 Re: Re: unknown crawler in reply to todd, 02-03-2000 20:39:39
the crawler i found is a hg oliver that the motor was replace with a wisconson
JOHN SAVOY
04-06-2002 14:00:11
 Re: Re: Re: unknown crawler in reply to todd, 02-05-2000 22:14:16
i just got hg no motor was thinking
of useing my ve-4 wisconsin any info
you can share might help thanks JOHN
JOHN SAVOY
04-06-2002 14:02:41
 Re: Re: Re: Re: unknown crawler in reply to JOHN SAVOY, 04-06-2002 14:00:11
