Serial # for Detroit Diesel 4-71
Gary Hearn
01-17-2000 19:05:30
Does anyone have access to a serial number list that covers the 4-71's? I purchased one with a sawmill and would like to know the year and HP. The local dealer is new at this and doesn't have any old books.
Thanks.
john
04-01-2001 14:35:23
 Re: Serial # for Detroit Diesel 4-71 in reply to Gary Hearn, 01-17-2000 19:05:30
Behind the govn. there is a machine surface or pad. This pad will either be stampped or tagged. On this will be the model number and serial number. By using the model number you can find out the orginal spec's including horsepower rating. Contact a detroit diesel distributor for remanufactured engines they maybe able to help. If you don't Know of one there are tons of them on MSN search. For example Central Detroit Diesel Allison, Inc.
Fred
01-18-2000 19:30:00
I will try yo help. is it a 2valve or 4valve? is it a high block or low block? what injector # ? 2 valve HV7 injectors about 100HP@1800 RPM 4 valve N65 injectors about 150HP@ 2250RPM
