American tractor corp crawler ?
chuck
01-25-2000 18:23:46
I think I have a ATC crawler, it has a Atc on the grill it has a flat head 4 cly gas engine. not having muck luck finding imformation. any help would be great.
Mike Geer
03-08-2000 10:58:11
 Re: american tractor corp crawler ? in reply to chuck, 01-25-2000 18:23:46
Chuck:
I Have service manuals for the ATC...4cyl. engine.
The ATC was called a "Terra Trac" and it was made by the American Tractor Co. e-mail me or give me a call....(909)674-6500. My Terra Trac. has a 4 cyl. engine...and is still fully operational, however it does need steering brakes.
CHARLES IRLAND
08-24-2000 22:38:23
 Re: Re: american tractor corp crawler ? in reply to Mike Geer, 03-08-2000 10:58:11
TERA-TRACK DOZERS ARE STILL WORKING ALL OVER THE COUNTRY SOME PARTS ARE AVAILABLE THROUGH YOUR LOCAL CASE INDUSTRIAL TRACTOR DEALER CASE MERGED WITH TERA- TRACK IN THE MID 50'S YOU MAY BE ABLE TO GET TRACK AND UNDERCARIAGE PARTS FROM A CO. CALLED [BERCO] THEY MAKE MOST OF THE TRACK PARTS FOR ALL THE DOZER CO.S IN THE WORLD YES EVEN CAT AND JOHN DEERE.
TERRY
06-24-2003 22:04:15
 Re: Re: Re: american tractor corp crawler ? in reply to CHARLES IRLAND , 08-24-2000 22:38:23
I THINK I HAVE AN OLD TERA TRAK CRAWLER, I AM SEARCHING FOR ALL THE INFO ON THE TRACTOR AND THE ENGINE
10-05-2001 20:18:37
i'm looking for a PRICE on a 140 or 162 Continental diesel motor for a tera track..
but i can't even find the motor.. -help please?
jeff yelton
11-26-2000 15:00:30
i have a terra trac dozer g300 serial number 162i would like to know about what year this dozer was built. The machine will be ment condition when i am done. courious as to value Thank You
Jeff Yelton 1-800-628-4602 please call Thank You
Dan Trimbach
05-04-2001 15:52:50
 Re: Re: Re: Re: american tractor corp crawler ? in reply to jeff yelton, 11-26-2000 15:00:30
I have a ATC Tera-Tract that i need parts&service manual. The main parts i need are gear cover & drive sprocket Dan
D Smoker
01-26-2000 19:31:44
What Tom said is correct. This webpage has some good information. www.msoe.edu/~swartb/terra.html
Undercarriage parts for some of the early models are really tough to find.
Tom from Ontario
01-26-2000 10:58:23
Chuck: Those crawlers went by the name Terratrac and the company was swallowed by J.I Case in the mid 50's. Engine is probably a Continental and very likely the same engine that was used in some models of Massey Harris tractors. Parts are still available but require searching. Get on the Crawlwers and Dozers page on this site and also the Case and David Brown site. Good Luck. Tom
