Oliver made in Italy
Leon Dupont
01-30-2000 09:27:06
I have an Oliver tractor that was made in Italy according to the nameplate. It is a 35-40 Hp. tractor and has the Later features like power steering, live pto., would guess to be in the 1970 models. Mod.#32521007 and Ser.#742952 are on the nameplate. The engine is a 4-Cyl.Fiat. Trans. is a six speed hi-lo range. Would appreciate any info you may have as to parts available and what tractor this is. thanks
JAY N
06-07-2000 13:38:05
 Re: Oliver made in Italy in reply to Leon Dupont, 01-30-2000 09:27:06
The number that you have matches a 1969 oliver 1250 made in italy. check out serial #'s to the left. Hope it helps if you have not already found it.
Woodbeef
02-01-2000 15:07:58
What you have is a tractor that was sourced(badge engineered) from Fiat.According to what I can find,a serial# in the 7s is from a 1365,or 1370.I can not find any numbers that high though.they stop at 1975,with a begining # for that year of 729125.if they went as high as yours than I guess it is a 75 model.It was a 55-60 hp. tractor.Is your sheet metal rounded or more square?Parts should be available from any Agco dealer in their Heritage line.New Holland dealers might be able to help you too.
If you have Long dealer try them, at that time they were the same
02-06-2000 17:02:43
 Re: Re: Oliver made in Italy in reply to Woodbeef, 02-01-2000 15:07:58
