Leader Model D parts
Dean Glover
02-23-2000 18:13:22
I have a Leader Model D tractor that I want to restore, and am looking for parts sources. The engine is stuck, so will probably need oversize pistons, rings ect. Also, a question: this tractor has a Hercules IXB5 engine. What is the difference from a IXB3? It appears that they are both 133 cu. in. displacement. Are parts interchangable? Thanks for your help, Dean
CD
02-25-2000 21:46:50
 Re: Leader Model D parts in reply to Dean Glover, 02-23-2000 18:13:22
Dean,
The IXB, IXB3, IXB5 all use the same valve train, timing gears and bearings. The "5" usually runs a higher compresion head- you have to check the code numbers on the head.
TRW and Perfect Circle both make a .083 oversize Ford 8N piston which has the correct wrist pin height and diameter for under $30.00 each - the Hercules pistons will run you about $140.00 each.
The Ford pistons have a dome which will increase your compresion, however, some clearancing may be needed on the head. Have fun!
CD
02-26-2000 05:14:34
 Re: Re: Leader Model D parts in reply to CD, 02-25-2000 21:46:50
I forgot to say that those Ford pistons are .020 over for IXB3 or IXB5.
CD - Also........
02-25-2000 21:55:48
I need to add that you should take special care to save all the bearings you can, because they're harder to find than a smooth running John Deere.
