Avery V carb
tom
02-28-2000 12:08:22
My tillotson carb is dead. They are no longer available. What now?
dennis
02-28-2000 21:02:06
 Re: Avery V carb in reply to tom, 02-28-2000 12:08:22
Buy a replacement for a farmall cub from CT farm/country at 1 800 8CT-farm. It is a Zenith that is the same bore for the same 60 cu-in engine size. you may have to change the fuel line but should fit and run fine. You may also have to change the air cleaner hose. I couldn,t find one for mine either other than used from Bill Williams for almost as much as new. Dennis
