3 point lift
Kendall Tomilso
02-29-2000 16:34:59
My father has a 1994 B7100 HST 16hp diesel. The lever to activate the lift for the 3 point hitch seems to work correctly but it doesn't move the arms up. Can anyone help? Thanks
Phil St Jean
07-14-2000 07:31:40
 Re: 3 point lift in reply to Kendall Tomilson, 02-29-2000 16:34:59
Most of those little japs have a pickup screen in the transmission bottom where the hyd pump feed line connects. Some of them will come out along with the large bolt securing the pipe to the casing , others come out from the opposite side. the oil needs to be drained out first to help prevent dirt from bypassing the screen and entering the system.cleaning the screen with diesel fuel is usually all you need , unless the screen has some puncture damage . It should then be replaced to prevent dirt from getting to the hyd pump,cause very little dirt can cause lots of damage.
