Injector Pump Install
Fuel Problem
Trey
03-05-2000 19:48:59
1978 Long 360
Had diesel injector pump rebuilt. After installing rebuilt pump, I cannot get fuel to the injectors. Filter has fuel. Fuel is in the pump, I can even get fuel to squirt out at the small bleeder screw on the pump, but can't get fuel out of the tubes feeding the injectors. I've tried turning the motor over (for hours, it seems) and also tried using a small suction pump. But still NO FUEL. Please help
marv
03-05-2000 20:37:38
 Re: Injector Pump Install - Fuel Problem in reply to Trey, 03-05-2000 19:48:59
Open bleeder plug on primary filter. Move hand pump till fuel only comes out. Close plug. Repeat on secondary filter. Open plug on outboard side of injection pump. Work hand pump till fuel only comes out and close plug. Repeat at plug on inboard side of injection pump at top. Loosen high pressure lines at injectors. Crank engine till fuel comes out. Tighten lines and start engine.
