David Brown 880
Rob Knebl
04-10-2000 06:53:21
Does anyone know the oil viscosity recommended for the diesel engine installed in the David Brown 880 Selectmatic? Any information would be appreciated.
Sarah
02-11-2001 13:25:25
 Re: David Brown 880 in reply to Rob Knebl, 04-10-2000 06:53:21
We have our hands on a 1969 uk spec version and Twinkle uses 15/30 ww oil(she prefers it to oil of olay!!!)which is the same as the gearbox oil,now can you help us getting her to lift her arms up...hydraylics not working and the filter has been cleaned along with the husband!!!!
Tom from Ontario
04-10-2000 18:12:05
If you ever see a manual for one of these, they will quote different viscosities for roughly every twenty degrees difference in air temperature. You can pretty well avoid all this by using a good, reputable brand of oil in 15-40 viscosity. Will flow in cold weather and still protect at full throttle in the middle of summer. We have it in everything from the lawnmower to the combine. Simplifies stock keeping as well. Tom
