Howard Gem Rotary Hoe Operation
Jon
04-11-2000 15:36:57
Ok, so I have a old Howard Gem walk behind rotary hoe. It has a dual tank for petrol and oil.
I gues the smaller tank is for oil - but what sort of oil?
What sort of spark plug should I be using?
What is the starting procedure?
Jon
JohnBev
09-17-2004 01:49:29
 Re: Howard Gem Rotary Hoe Operation in reply to Jon, 04-11-2000 15:36:57
where can I get parts or a manual for this mower ?
Any1 got a contact number for a supplier ?
(engine has seized up)
Len O neill
11-02-2003 12:15:08
Hi Give me a call if still interested and I can help len
David Perrin
04-14-2002 10:17:33
Hi from Wales U.K.
Interested to read the above regarding Paul and Doug's replies.
I am servicing an old "Gem" with twin tanks and Jap 5 engine. Can anyone date the machine? I would also like to know the correct oil and currently propose using ordinary engine oil.
Re-lack of spark: Have you checked breaker points and condition in rear of Magneto. Any help on my problem would be much appreciated as would a reply to david.jp@btopenworld.com
Thanks
David Perrin
Tony Brooks
04-14-2002 15:13:34
 Re: Re: Howard Gem Rotary Hoe Operation in reply to David Perrin, 04-14-2002 10:17:33
Nice to know there are other people about with an obscure facination for Howard Gem's. I am the owner of 3 machines in various states of repair. The fuel tank is not split for petrol/oil but for petrol in the small tank and TVO (tractor vaporizing oil) in the large tank. You will see that the fuel pipes from the tank are connected just before the carb. You start up on petrol and once the engine is warm, turn off the petrol and turn on the TVO. When hot, it will start on TVO but when cold it needs pure petrol (no TVO contamination). There is a drain tap on the bottom of the carb to drain the TVO out so you can fill the carb with petrol. Hope this is of interest to you.
Gra
04-06-2006 00:34:07
 Re: Re: Re: Howard Gem Rotary Hoe Operation in reply to Tony Brooks, 04-14-2002 15:13:34
Do u know anywhere where I can details on tuning, operating and servicing the J.A.P. (500cc?) engine.... I have one on a Howard GEM with twin tank more or less as u describe.
Thanks Gra
Steve Mundy
02-18-2001 17:21:33
For more infomation on Howard Rotavator, Contact Howard USA Inc., 10 S. Jefferson St., Harvard, IL 60033. Phone No, 815-943-5401
Steve Mundy
Paul Hurley
02-28-2001 02:04:48
 Re: Re: Howard Gem Rotary Hoe Operation in reply to Steve Mundy, 02-18-2001 17:21:33
Jon,
I have a later model Gem, but i know a collector who has every model (they were designed and originally built in Oz) if you can supply more info. I may be able to give you an update.
Doug
09-17-2001 01:06:17
 Re: Re: Re: Howard Gem Rotary Hoe Operation in reply to Paul Hurley, 02-28-2001 02:04:48
Why won't the magneto produce a spark on my Howard?
