General gg
Macc
04-16-2000 12:29:24
I have a few questions. my tractor wears serial #1FA626 what year does this make it? 39? Mine has a foot throttle all the pics ive seen show a hand throttle?? Did 39 GG's have starters? Where does mine fall as to the number of tractor built? Thats it for now Thank you. Macc
keith ault
04-16-2000 18:04:21
 Re: general gg in reply to Macc, 04-16-2000 12:29:24
yours is a early 39,they used only even serial numbers,starters were a option,I have one with out a hole in the bell housing for a starter,I have never seen one with a foot throttle.The early ones were a transition and used what ever parts were available(some cletec trans)It has a IXB Hercules engine,Clark rear end and transmission.We recently toured the building in Louisville Ky where operations were moved after Cletrac sold out to Avery.Let me know if I can help on anything you need Keith
macc
04-18-2000 14:25:42
 Re: Re: general gg in reply to keith ault, 04-16-2000 18:04:21
Did they start with 002 being the first one built?
The foot throttle is bolted to the frame in the same place the hand throttle plate is, I think. Its been a few months since I last saw one. I have no pics or info. The linkage all hooks up the same and appears to be the same configuration.?? Mine has a place for a starter but no batt. box, no gen. and no wires. For restoration purposes then a starter would be ok? Does the plant in Louisville have any info or history on the gg?
It would be very interesting to find out if the foot throttle was a early means of throttle control carried over from the crawler line. what do you think?? Then i do'nt know if they used foot controls on the crawlers do you?
