Co-op E3
toolbox
06-07-2000 18:09:34
I saw a Co-op E3 parked in the woods. It's been there awhile. It looked nice, doesn't run, sheet metal good, rims bad, standard wide front, PTO, drawbar, no 3 point. I'm more into Case, so don't know anything about Co-op. What's the general value for an E3 like this, and are parts available for restoration? Thank you for your help.
bg
06-11-2000 19:16:35
 Re: Co-op E3 in reply to toolbox, 06-07-2000 18:09:34
Same tractor as Cockshutt. pretty good, neat tractors and worth restoring if not in too bad shape. I've seen them from $500-3500, D.O.C.
idlem
06-07-2000 20:40:21
First thing to do is check block for crack,these engines were bad about cracking.If motor is cracked and stuck or just stuck your looking at about 400.00.If motor is free and not cracked and
sheet metal is good about 800.00.Parts can still
be found for these tractors.Kenny
