Avery A
Magneto QUESTION ?
Alberta Mike
06-13-2000 10:38:13
If you own an Avery A (with a Wico mag with a Hercules engine), please run out to your machine shed and then come back and answer these questions for me:
If I face the magneto from the tractor seat, which terminal on the mag is the #1 wire, the top right, bottom right, bottom left, or top left?
What is the firing order?
Am I correct in assuming that the wires are installed in clockwise order?
Knowing this would save me a lot of time finding out the hard way. Someone has removed all of the plug wires. Thanks
larry
06-13-2000 16:51:21
 Re: Avery A - Magneto QUESTION ? in reply to Alberta Mike, 06-13-2000 10:38:13
Firing order is 1243. The service manuel says its marked and dosn't say which one. If timeing gears where not removed the roter will point at number 1 or 4. the book sayes to instal to dc mark, then adjust mag. so points just start to open with flywheel on spk mark.
