Avery A wiring question
Alberta Mike
06-29-2000 10:59:31
I have a '45 model A Avery tractor. It has a mag ignition and a battery start with a generator for charging. I'm going to rewire everything and quite a lot of it was rotten and hanging into space. I know the wiring pattern of most of the old stuff from the 40's, it pretty much seems to be the same even between different brands. For example, 6-volt positive ground, the 3-way combination charging control and light switch on the dash, etc. Do you know if the Avery used this same basic pattern of wiring?
