Cockshutt 30 seals on axle
Irv Plitzuweit
06-30-2000 06:45:11
Had leakage on rear wheels and tires. After some measuring and searching found that National (Federal-Mogul) Seal 710219 did the trick. 108 mm outside and 90 mm inside/ I think)
Alberta Mike
07-01-2000 20:57:27
 Re: Cockshutt 30 seals on axle in reply to Irv Plitzuweit, 06-30-2000 06:45:11
I also had problems finding seals for my Cockshutt 30. Apparently there were no cross references for the original Rockwell seals that Cockshutt used. The guy at the local bearing house found some that worked fine. They were Johns Manville (JM) Clipper series seals, number 0350-09728. Good idea to post stuff like this since some of us often get dead-ended looking for matches. See ya.
