Satoh S650G
transmission oil
John David Brad
07-03-2000 18:43:57
I just got this Satoh S-650G tractor recently and am trying to take care of it as best as possible. (It had been sitting for awhile...)
In checking the transmission oil, there doesn't seem to be much in it. How do you know when it has the proper amount of oil? Is there a dip stick or sight glass? Does it use hydraulic oil or does it use 80-90 weight gear oil? Is the transmission oil separate from the hydraulic oil?
I have ordered the manual reprint, but would like to do some work while waiting for the manual to arrive...any help would be appreciated.
Thanks,
JDB
Roland Roy
07-05-2000 05:20:25
 Re: Satoh S650G - transmission oil in reply to John David Bradshaw, 07-03-2000 18:43:57
Satoh 650G manual calls for sae 80 below 20 deg F sae 90 20 to 90 deg F. There is a sight glass on left side of the transmission which is difficult to see through . I make sure the oil level is above the gears which you can see in the fill hole.
